Jordanm Reputable Nov 22, 2014 42 0 4,530 Feb 28, 2015 #1 i have one exhaust at the back and 2 intakes on the front (fractal r4 case) avg temps idle 30 to 60 on load
Solution B B boosted1g Feb 28, 2015 Adding a top fan to the define r4 will increase noise, if temps are fine then there is no reason to add another fan
B boosted1g Titan Jun 12, 2013 14,847 9 81,765 Feb 28, 2015 Solution #2 Adding a top fan to the define r4 will increase noise, if temps are fine then there is no reason to add another fan Upvote 0 Downvote Solution
