Is there such a device as a wifi (not bluetooth) keyboard?
Mark Touhig
5
I have an old Motorola Xoom tablet. It has BT but it loses connection to a keyboard roughly 10% of the time. I think this is because the machine antenna is shared between BT and wifi (poor design I guess). It would be okay if there is a wifi keyboard should any exist as I am always near a wifi router. Does anyone know?
no, i'm not aware of any such keyboard. the major connection types are:
-bluetooth (often limited on range, receiver dongles are small)
-rf wireless (can have ranges up to 40-60ft but hard to find, dongles are larger)
-infared (straight line of sight only)
-wired
keep in mind that all of them except bluetooth require a physical connection port on your device to use (usb normally) so if your device doesnt have one or is incapable of supporting a device over usb then it wont work.
you might be able to connect using a wifi usb hub like this http://www.engadget.com/2011/08/05/iogear-usb-sharing-station-connects-to-wifi-cuts-the-cord-on-fo/ but i cannot offer any details on how to do this and if its feasible. i only saw it mentioned so passed along the information.
Thank you Emerald. You mean a nano USB I think, but unfortunately the Xoom has no USB port. It does have a port where I can insert a OTG on the go cable and I have tried standard wired USB keyboards and memory sticks \ flash drives but they don't work. It's an old tablet I know but other than that issue I'm still happy with it.
Thank you, too, ssddx. My genuine motorola BT mouse is 100% okay, it's just the unknown name keyboard that is iffy. I can't figure why OTG cable doesn't work and I guess I could try another make of keyboard. - just a little reluctant to buy one if going to have same problem 🙂
