^This is my first time buying aftermarket thermal paste and after doing some research, I found that some thermal pastes are incompatible with some heat sinks due to some problem with metallic composition (Lack of Silver/Copper I think) of either the paste or the heat sink.
I have had this computer for ~5 years and am using an Intel i5 4670k. I have never replaced the thermal paste (I know now...bad idea). I was curious today about my CPU temperature and realized that I'm running at a consistent 80-85c under load. Then (and please don't laugh at me for this), I didn't look up whether that was too hot or not before I attempted to overclock for the first time. When I did my CPU core temperature shot up to a consistent 100 degrees and when I went back to the original clock speed, it still is remaining at 95-100C under load...So I'm assuming - and hoping - that all I did was partially "burn off" the remaining 5 year old stock thermal paste and that I just need to replace it ASAP.
So, the title is my ultimate question, but I suppose I should add on: How can I check for myself whether or not the two are compatible? I attempted to look up specs for both the H100i and Thermal Grizzly Conductonaut but I'm uncertain as to what I should be looking for; should I ever need to know in the future.
P.S
- I did a lot of searching around and came to the conclusion that the Thermal Grizzly Conductonaut
is one of (if not the best) thermal pastes I can purchase. Is this true? If not, what would you suggest? Consider this: Within 2 months I plan on putting together another build with an Intel i7 8770k (Which I plan to OC) and the H100i v2.
Thanks in advance for any help.
P.S
