Hello. I have recently got my hands on an Rx 460 4gb Gpu. I found out that i didnt have a 6pin power connector, so i took it to a Pc Service shop, and got a new Psu. Its a Corsair 620w power supply. (I used to have a 420w Spire) My pc runs very good, and im able to do a lot of work, and I can use it for gaming. My issue is that the pc overheats fairly quickly. When its Idle it runs ok (still a bit too hot) at 76°C. However not 30 mins in its in the 82-88°C area and sometimes even more. The pc is completely clean of dust, and while i do use a stock cpu cooler, i havent had any problems with it. I havent tried adjusting fan speeds yet. My best guess for dealing with this problem is by replacing the old thermal paste. (I got the pc 3 years ago, and it has never been changed.) Also the old thermal paste apply was a bit bad to say the least. The paste is extremely thin by the looks of it, almost as if there isnt even on at all. I'm planning on buying a good thermal paste tomorrow, and use the pea sized drop way of doing it (I have applied thermal paste before like this). Do you guys think that it will work? If this fails, i might think about getting a better cpu cooler. Does the heat of the Cpu affect the Gpu temperature aswell?
