Is this a good 3Volt battery for my motherboard?
THose may be too thin. A standard 3v cell for the system CMOS is a CR2032, the CR2016 is only about half as thick, and might make poor contact if it closes the circuit at all.
Also, a two pack might be overkill, these batteries can last a good while, three to five years.
Thank you for warning me those wouldn't fit. Thank you very much I will buy the ones you recommended!
