Build Advice Is this a good pc parts list? forgot to mention but I'm in Canada
Znn
Commendable
Aug 30, 2022
79
13
1,545
image of pc parts list
Are the PC parts good enough for VR gaming?
So this is my first time ever building a PC. I'm planning to build it for VR gaming and I'm planning to buy parts and build the PC near the summer holidays. Does anyone have any useful links for new builders? I know there are lots on youtube but does anyone have anything that they personally found useful?
cpu - Intel Core i9-13900K 3 GHz 24-Core Processor
cpu cooler -
motherboard - Asus TUF GAMING Z690-PLUS WIFI D4 ATX LGA1700 Motherboard
memory - G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory
storage -
GPU -
case -
power supply - Corsair RM1000x (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply
case fan
Spending so much money, you should just go DDR5, to get the most out of that 13900k. I compiled your parts, into a single list.
PCPartPicker Part List
CPU: Intel Core i9-13900K 3 GHz 24-Core Processor ($781.50 @ shopRBC)
CPU Cooler: Lian Li Galahad AIO360 (2022) 69.17 CFM Liquid CPU Cooler ($314.97 @ Amazon Canada)
Motherboard: Asus TUF GAMING Z690-PLUS WIFI D4 ATX LGA1700 Motherboard ($349.99 @ Newegg Canada)
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory ($198.74 @ Amazon Canada)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($329.99 @ Amazon Canada)
Video Card: Asus TUF GAMING GeForce RTX 4080 16 GB Video Card ($2049.98 @ Amazon Canada)
Case: Corsair 4000D Airflow ATX Mid Tower Case ($119.99 @ Best Buy Canada)
Power Supply: Corsair RM1000x (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($266.05 @ Vuugo)
Case Fan: Lian Li Uni Fan SL-Infinity 61.3 CFM 120 mm Fans 3-Pack
Total: $4411.21
Generated by PCPartPicker 2023-01-25 13:11 EST-0500
Based on this, this is how I would spend that much.
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler ($189.99 @ Memory Express)
Motherboard: Gigabyte Z790 AORUS ELITE AX ATX LGA1700 Motherboard ($364.99 @ Canada Computers)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory ($289.99 @ Newegg Canada)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($200.50 @ Vuugo)
Video Card: Gigabyte EAGLE OC GeForce RTX 4080 16 GB Video Card ($1699.00 @ Canada Computers)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case ($144.05 @ Vuugo)
Total: $3936.07
Generated by PCPartPicker 2023-01-25 13:17 EST-0500
https://www.guru3d.com/news_story/s...a_rapidly_declining_lifespan_for_the_ssd.html
https://ca.pcpartpicker.com/product/KKytt6/lian-li-lancool-216-atx-mid-tower-case-lancool-216rx
Lian Li LANCOOL 216 ARGB ATX Mid Tower Case $144.05
https://ca.pcpartpicker.com/product...-fully-modular-atx-power-supply-cp-9020200-na
Corsair RM850x (2021) 850W 80+ Gold Modular Power Supply $179.50
https://www.ebay.ca/sch/i.html?_fro...1313&_nkw=corsair+600w+12vhpwr+cable&_sacat=0
Corsair 600W 12vhpwr Cable $53.30
https://ca.pcpartpicker.com/product/8ncG3C/gigabyte-z790-ud-ac-atx-lga1700-motherboard-z790-ud-ac
Gigabyte Z790 UD AC $274.99
https://ca.pcpartpicker.com/product...13700f-21-ghz-16-core-processor-bx8071513700f
Intel Core i7-13700F $499.00
https://ca.pcpartpicker.com/product...k-argb-6788-cfm-cpu-cooler-r-ag620-bkanmn-g-2
DeepCool AG620 BK ARGB CPU Cooler $77.98
https://ca.pcpartpicker.com/product...6-gb-ddr5-5600-cl36-memory-cmk32gx5m2b5600c36
Corsair Vengeance DDR5-5600 32GB (2x16GB) CL36 $179.99
https://ca.pcpartpicker.com/product...b-m2-2280-nvme-solid-state-drive-mz-v7s2t0bam
Samsung 970 Evo Plus 2TB M.2 PCIe 3.0 x4 NVME SSD $220.50
https://ca.pcpartpicker.com/search/?q=RTX+4070+Ti
RTX 4070 Ti 12GB $1119.00
Total: $2748.51 CAD
https://ca.pcpartpicker.com/product...7aql1a-270-2560x1440-170-hz-monitor-vg27aql1a
ASUS TUF GAMING VG27AQL1A 1440 HDR 170Hz IPS G-SYNC Compatible Gaming Monitor $433.99
A better look at those components.
https://lian-li.com/product/lancool-216/
https://www.gigabyte.com/Motherboard/Z790-UD-AC-rev-10#kf
https://www.deepcool.com/products/C...K-ARGB-Dual-Tower-CPU-Cooler/2022/16082.shtml
https://www.intel.com/content/www/u...-30m-cache-up-to-5-20-ghz/specifications.html
Reactions: Znn
Thoughts on going Ryzen and AM5? If you were looking for a long term support build AM5 is supposed to be supported for the next 4.5 years.
to be honest I have no idea. Im slowly looking into how I can build a PC so I don't know what you're talking about atm. Ill definitely consider what you're saying once I've learned a bit about pc's
Reactions: artk2219
Total: $2748.51 CAD
awesome! thanks for the useful stuff
Reactions: Why_Me and artk2219
Realistically for what youre doing, even with VR, you dont have to spend 4k CAD. You could get a good build for around half of that and upgrade in the future as needed.
I sort of understand that, I might get a cheaper CPU. But like ideally I'm hoping to get stuff similar to the list because its better than my prebuilt, which is probably a mid range PC and is still struggling a bit to run vr at high quality. So basically, I'm building PC to be able to run vr on high graphics and to withstand some other high end games I play for a smooth experience
to be honest i don't think i'd be able to tell you anything useful since I haven't gone to that store, or any other PC parts store yet. I do have discord, if you want to chat you can message me or just reply with your username and I'll add you
Just throwing this out there, if you did want to look at cards other than the 4080 youve got some more options, at the very least you can look at the RX 7900 XTX. The 7900 XTX offers up a bit more performance for generally less if you don't count ray tracing, and honestly you shouldn't, at least not yet, theres nothing that really makes it a must have feature yet, and by the time there is, you'll likely need a new card anyway. I just threw something together with a more mid range cpu, same amount of ram, same amount of storage, 850w psu instead of 1kw, and an RX 6950xt that has around 80% of the performance of an RTX 4080 at 1080p and 1440p, it is a blow out at 4k though, with the RTX 4080 leading by 35%, but for 80% more money. I've attached the RX 7900 XTX review because it has all the cards mentioned, and Toms CPU hierarchy. I'm just letting you know you have options is all, you could get like 80%+ of the performance, for half of the price.
https://ca.pcpartpicker.com/list/Yw6ZyK
https://www.tomshardware.com/reviews/amd-radeon-rx-7900-xtx-and-xt-review-shooting-for-the-top/6
https://www.tomshardware.com/reviews/cpu-hierarchy,4312.html
Just throwing this out there, if you did want to look at cards other than the 4080 youve got some more options, at the very least you can look at the RX 7900 XTX. The 7900 XTX offers up a bit more performance for generally less if you don't count ray tracing, and honestly you shouldn't, at least not yet, theres nothing that really makes it a must have feature yet, and by the time there is, you'll likely need a new card anyway. I just threw something together with a more mid range cpu, same amount of ram, same amount of storage, 850w psu instead of 1kw, and an RX 6950xt that has around 80% of the performance of an RTX 4080 at 1080p and 1440p, it is a blow out at 4k though, with the RTX 4080 leading by 35%, but for 80% more. I've attached the RX 7900 XTX review because it has all the cards mentioned, and Toms CPU hierarchy. I'm just letting you know you have options is all, you could get like 80%+ of the performance, for half of the price.
The 7900xtx is definitely an option. PCPP is showing one that is about $100 less than that 4080 I linked earlier.
https://ca.pcpartpicker.com/product...x-7900-xtx-24-gb-video-card-rx7900xtx-pg-24go
Sure i will dm you check you forum messages
I have messaged you in forum private messages check it . Discord included
