The connectors are those ribbed type, you know..... The common type, and slip the tube on over it.
I was going to put marine sealant stuff on the connector then put the tube over that so it really makes a water tight seal. Then put a hose clamp on, the screw on type.
Does this sound good? Or is the sealant a bad idea?
