Is this a good power supply in general ?
I don't buy from websites only from local stores, there an XFX pro series 850w 80 bronze but it's for much more, around 140$.. btw i'm from jordan and my budget is around 140
This is my system :
-Mobo - ASUS P8Z77-V PRO LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-CPU - Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core
-GPU - SAPPHIRE Vapor-X 100352VXSR Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16
Or 2x Gigabyte 7870 Ghz Edition in Crossfire - (still cant decide)
-Ram - CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866
-HDD - Western Digital WD Black WD1002FAEX 1TB 7200 RPM
-Case - Cooler Master HAF 912
-PSU - ??
-Two CM Megaflow 200m fans
and these are the PSUs I can get localy here
XFX pro Series 850w/650w/450w 80 Bronze
Cooler Master extreme 600w/700w
Thermaltake TR2 700w
Corsair CX 500w
and that's about it
So about the GPU's . I see u like AMD so bettwen those card u mentioned i would say go with 7950/70 and add CF later in future.
And the PSU XFX 850 W would be great as you are going to CF.
7950CF need 360W ----> Xfx 650W
7970 CF need 520W ----> Xfx 850W
Thanks I will use your advice :)
