Is This A Power Supply Problem ?
vikas_sharma
61
I just installed a new ram of 1333mhz cause my previous ram damaged dat was also of 1333mhz
Now when i power on my pc it does not but cpu and gpu fans runs i tried many times sometime it power on and window boot and many of the times it does not power on also windows freeze / crash
And if by change i success in login to windows and try to put pc on sleep mod it doesn't work and after 1-2 minutes all fans stopped but now if i again try to power on from sleep mod then no signal to monitor / mouse / keyboard
What could be the problem ?
Motherboard Ram Or Power supply ? Plz help me
vikas_sharma
61
My previous ram was also of transcend 4gb ddr3 1333mhz
Computer does not power on i mean when i press the power button it does not give signal to monitor , keyboards , mouse but gpu and cpu fans run and hard drive also
But it sometime power on rarely if i try several time but in that also window freezes and blue screen of death :\
wllmgrms
213
Sounds like it could be a video card or power supply problem... I would hate to think it's CPU. If you know anyone who has an extra PSU or video card you could use, it would be the easiest way to determine what your computer is doing.
vikas_sharma
61
I tried with another power supply same problem.
Also i tried removing video card and running monitor on board graphics still same condition,
Even i tried changing cpu also still same
What could be the problem now ?
