So the other night I went to turn my PC on and when I did the lights can on and the fans started running but nothing showed up on my monitor. I tried 2 other different monitors and same thing. I tried turning the pc off and on several times and then all of a sudden it worked. Everythings good right,,, wrong! After shutting it down that night the next night when I went to start it same thing only this time I could not get it to turn on at all. Its a Dell system and it still under warranty so I called tech support. They had me completely unplug both my pc and monitor for 20-30 seconds and plug everything back in. It booted up , the tech support took over my pc for a bit and updated bios and different things like that and everything seemed fine. Next day got up and turned my pc on and it booted up no problem. Shut it down for a while when I was out and booted up again no problem. Tonight when I got home from work it would not boot up, same problem as before ( lights on and fans running but nothing on my monitor) , so I unplugged the PC and monitor and plugged it back in and same problem , tried a second time and it booted up. Im not really sure if this a a power supply problem or would it be a graphics card problem?
System is
Dell Inspiron 5675
Ryzen 7 1700x
gtx 1060 6gb
16gb ddr4 2400
450w power supply
dell 1440p 24 monitor.
Up until the other day I had never had problems with this unit and its ran fine.
Not sure whats going on with it now.
Thanks for any help !!
System is
Dell Inspiron 5675
Ryzen 7 1700x
gtx 1060 6gb
16gb ddr4 2400
450w power supply
