Is this build compatible and will it work
xextrie
I am building a PC and I just want to check and see if everything is looking good, also some airflow help. I am getting these following components;
Noctis 450 Case
AMD Ryzen 1700X
ASUS ROG STRIX X370-F
ASUS ROG GeForce GTX 1080 Strix
G.SKILL TridentZ 16GB DDR4
Corsair RM850x
NZXT X62
Next I am thinking about how I am going to install the AIO CPU cooler I want to install the 280MM radiator on the outside of the case inside the plastic cover of the case and then have the fans inside the case blowing air out of the top. I also have 3 120MM fans pulling air in from the front. There is also a 140MM fan at the back to exhaust.
well.. i could suggest something like this for you.. it's not exactly in BUDGET FRIENDLY zone.. so there is space for tweaks. have a look maybe you'll find something better
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($414.00 @ B&H)
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler ($89.95 @ Amazon)
Motherboard: Gigabyte - Z370 AORUS Gaming 5 (rev. 1.0) ATX LGA1151 Motherboard ($199.89 @ OutletPC)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3200 Memory ($194.88 @ OutletPC)
Storage: SanDisk - SSD PLUS 480GB 2.5" Solid State Drive ($129.99 @ Amazon)
Storage: Western...
gussrtk
Storage: Western Digital - RE4 2TB 3.5" 7200RPM Internal Hard Drive ($72.69 @ Newegg Marketplace)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC Black Edition Video Card ($743.99 @ SuperBiiz)
Case: Corsair - 760T Black ATX Full Tower Case ($169.99 @ Amazon)
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($103.69 @ Amazon)
Total: $2119.07
Generated by PCPartPicker 2017-12-01 21:31 EST-0500
if this build is for gaming, I would strongly suggest an INTEL CPU because it's generally stronger on single core processing, which is more important than how many cores the CPU has. GPU is good as is, but maybe the one i suggested is good too if price changes with all the parts. Cooling.... just stick to air, complicated is not always better you know
