F fourwheeler2000 Reputable Sep 30, 2014 35 0 4,530 Nov 25, 2014 #1 this is my first time build and don't want to mess it up just wanna know if these parts are gonna give me an awesome pc! http://pcpartpicker.com/user/fourwheeler2000/saved/cPv2FT
Solution Brunostako Nov 25, 2014 Yes, everything is OK. One suggestion, go with a FM2+ motherboard. That way you will have a CPU upgrade path.
Brunostako Honorable Dec 16, 2013 2,348 1 12,960 Nov 25, 2014 Solution #2 Yes, everything is OK. One suggestion, go with a FM2+ motherboard. That way you will have a CPU upgrade path. Upvote 0 Downvote Solution
Brunostako Honorable Dec 16, 2013 2,348 1 12,960 Nov 25, 2014 #4 Also use a bigger PSU. 500W is somehow low for the R9 280X. Upvote 0 Downvote
F fourwheeler2000 Reputable Sep 30, 2014 35 0 4,530 Nov 25, 2014 #5 this is the updated version http://pcpartpicker.com/p/sv9jbv i went with the PSU upgrade also because i wanted to SLI the 280X's at some point Upvote 0 Downvote
Brunostako Honorable Dec 16, 2013 2,348 1 12,960 Nov 25, 2014 #6 Great. Just an advise for the future. If you stay with the 760K, you will face huge bottlenecks with a 280X crossfire. You may need a platform upgrade at that moment. Upvote 0 Downvote
F fourwheeler2000 Reputable Sep 30, 2014 35 0 4,530 Nov 25, 2014 #7 platform upgrade? ill definitely upgrade the CPU before the gpu Upvote 0 Downvote
Brunostako Honorable Dec 16, 2013 2,348 1 12,960 Nov 25, 2014 #8 Hopefully AMD will have something that can support a 2-way crossfire without causing bottlnecks. If not you will need to switch to Intel. Upvote 0 Downvote
logainofhades Titan Moderator Apr 27, 2009 38,723 4,061 143,290 Nov 25, 2014 #9 You can do better, for a similar cost, and have a better upgrade path. PCPartPicker part list / Price breakdown by merchant CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($94.99 @ SuperBiiz) Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard ($108.99 @ Newegg) Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory ($56.99 @ Newegg) Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Newegg) Video Card: Asus Radeon R9 280X 3GB DirectCU II Video Card ($241.70 @ SuperBiiz) Power Supply: XFX ProSeries 750W 80+ Silver Certified Semi-Modular ATX Power Supply ($77.99 @ NCIX US) Optical Drive: LG GH24NSB0 DVD/CD Writer ($15.98 @ OutletPC) Operating System: Microsoft Windows 8 (OEM) (64-bit) ($82.85 @ SuperBiiz) Case Fan: NZXT Air Flow Series 59.1 CFM 120mm Fan ($10.20 @ SuperBiiz) Total: $739.68 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2014-11-25 18:35 EST-0500 or PCPartPicker part list / Price breakdown by merchant CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($169.98 @ SuperBiiz) Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard ($108.99 @ Newegg) Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory ($56.99 @ Newegg) Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Newegg) Video Card: Sapphire Radeon R9 280 3GB Dual-X Video Card ($174.99 @ Newegg) Power Supply: XFX ProSeries 750W 80+ Silver Certified Semi-Modular ATX Power Supply ($77.99 @ NCIX US) Optical Drive: LG GH24NSB0 DVD/CD Writer ($15.98 @ OutletPC) Operating System: Microsoft Windows 8 (OEM) (64-bit) ($82.85 @ SuperBiiz) Case Fan: NZXT Air Flow Series 59.1 CFM 120mm Fan ($10.20 @ SuperBiiz) Total: $747.96 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2014-11-25 18:36 EST-0500 Upvote 0 Downvote
F fourwheeler2000 Reputable Sep 30, 2014 35 0 4,530 Nov 25, 2014 #10 no cpu cooler? Upvote 0 Downvote
logainofhades Titan Moderator Apr 27, 2009 38,723 4,061 143,290 Nov 25, 2014 #11 Don't need aftermarket cooling, for locked Intel cpu's. Upvote 0 Downvote
F fourwheeler2000 Reputable Sep 30, 2014 35 0 4,530 Nov 25, 2014 #12 oh but i plan to upgrade it to a i5 4690k will i need an aftermarket cooler then? Upvote 0 Downvote
logainofhades Titan Moderator Apr 27, 2009 38,723 4,061 143,290 Nov 25, 2014 #13 If you get the i5 4460, getting an i5 4690k is a waste of money. If you get the i3 and then get one, then get a cpu cooler at that time. Upvote 0 Downvote
F fourwheeler2000 Reputable Sep 30, 2014 35 0 4,530 Nov 25, 2014 #14 im gonna get the i3 for now thanks Upvote 0 Downvote
