Is This Fluid Okay For Water Cooling?
Mason1204
116
I will start with 5 ltrs of Ultra Pure H20 and then add PT Nuke. I will use Mayhem Dyes to make it a green color afterwards. Will this be a good fluid mix for my loop? I want it to be an opaque color but if this makes it transparent that's fine too. If someone knows a better way to make it opaque, then let me know. Thanks!
Links:
Ultra Pure H20: https://mayhems.co.uk/coolants/other/ultra-pure-h20/5ltr-ultra-pure-h20/
PT Nuke: https://www.amazon.com/Petras-Tech-Nuke-Concentrated-Biocide/dp/B008EGYJ54
Mayhem Dye: https://mayhems.co.uk/dyes/standard-dyes/uv-laser-green-15ml/
Since you're dealing with Mayhems products, Id say skip the biocide and go with either of these two options. Might I ask to see if your watercooling loop checks out? Some have gone with mixed metal components to only learn the disadvantages of it after building the loop.
