Is this gaming rig okay? Does these parts work fine with each other?
narutouzamaki2016
23
These are all the components I have chosen. Also I already have a HDD so didn't get a new one.n
CPU - Ryzen 5 1600
Mother Board - Gigabyte GA-AB350-GAMING 3.
RAM - G.skill Ripjaws V 8GB (1 x 8GB) DDR4 2400MHz
PSU - Corsair CX Series CX650M - 650 Watt 80 PLUS Bronze Certified
GPU - Gigabyte Aorus Geforce GTX 1080 Ti
Cabinet - Cooler Master MasterBox Lite 5 RGB Mid Tower Case
Monitor - Benq (XL2730Z) 27 inch 1440p 144hz
Should I get the asus prime b350 plus or is the gigabyte gaming 3 okay?
Thanks for your help!
Ok if Intel is too pricey but you will loose some fps in some games. Don't buy 1x8Gb RAM either as you will need to sell it later and buy a 2x8gb kit. Trying to add a second 8gb stick even of the same make and model is not guaranteed to work without problem. It is why RAM us sold in matched kits where tge sticks are tested to work together without issue.
Okay then I'm going with this G.skill 16GB (2 x 8GB) 3000Mhz DDR4 Ram.
I think I messed up with the vote thing saying -1. Sorry if it meant something negative. Didn't mean to do that.
Thanks for the help!
