Is this gpu fan speed/RPM safe?
gingfreaks
12
Hi Guys, I'm trying to keep my GPU temp below 70°C and in order to do so i changed the default fan curve. Now when it goes to 67-69°C,fan speed is at 70% with around 2500RPM.
Do you think that RPM will reduce the life span of the gpu fans?
GPU:Zotac 1060 AMP 6gb
Thanks in advance guys!
Oh that's just fine. If it's running at 35 idle, that's completely normal. As long as you can keep it below 80 while gaming, you will be fine.
Thanks a lot guys!I'm kinda worried. My ambient temp is around 22-25C my gpu on idle is 35C.I've read some reviews that the zotac version of 1060 really runs hot, it goes around 75-80C that's why i adjused the fan curve.
