Is this power supply adequate for my build?
Notadeny
4
Hey guys and gals, I was hoping you guys might help me decided if this power source is enough for the build that I am planning. It was relatively easy to pick my parts for my new build, but the choosing of the power supply just boggles my mind. Here are the pieces that I have chosen so far.
CPU: AMD FX-6300
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
Mother Board: GIGABYTE GA-990FXA-UD3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
GPU: R9-280X
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150678&cm_re=r9_280x-_-14-150-678-_-Product
So here is the power supply that I am planning to get.
EVGA 600B 600W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438014&cm_re=600B_600_Watt_ATX_Power_Supply_evga-_-17-438-014-_-Product
Thanks in advance for your assistance!
I got that piece from the micro center already, and when I follow through with the mail in rebate it'll come out to the same price. I just want to get all my pieces from there and take care of the rebate all at once.
Thanks a lot for the help.
If there is a suggesting for a better PSU, for a similar budget, I would appreciate the assistance.
I can't wait to put this bad boy together.
