S syponord Sep 21, 2018 2 0 10 Sep 21, 2018 #1 I bought a Fusitu PC, but I want to buy a new PSU too because the manufactured one isn't enough. I don't know If it will be compatible with my motherboard I have Fujitsu D3062-A1 motherboard. I plan to get a Chieftec Smart 600W GPS-600A8.
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 Sep 21, 2018 #2 I don't see that Fujitsu D3062-A1 model part number ending in 1. Fujitsu Mainboard D3062-A https://shop.itema-pg.com/userfiles/editor/file/DS_D3062-A.pdf Power Specification Fujitsu 12V only concept adopted Power Supply required Upvote 0 Downvote
S syponord Sep 21, 2018 2 0 10 Sep 21, 2018 #3 Calvin7 : I don't see that Fujitsu D3062-A1 model part number ending in 1. Fujitsu Mainboard D3062-A https://shop.itema-pg.com/userfiles/editor/file/DS_D3062-A.pdf Power Specification Fujitsu 12V only concept adopted Power Supply required Thank you for your anwser! Yes, you are right there is no number.But what does it mean? What type of PSU can I buy? Could you suggest a good one? Upvote 0 Downvote
