Is this power supply enough to feed my system
Rejoy_
Commendable
Jun 23, 2016
31
So guys I bought a gtx 560 twin frozer ii the other day and I realized I didn't have any 6 pin connectors for it. (It needs 2)
My 500w PSU only had 2 molex cables so I went on Amazon and bought 2 molex splitters and 2 6 pin molex cables.
Now I was just wondering if it's setup will work or will I have to buy a new PSU?
http://
That's the psu.
Thats things a fire hazard waiting to happen, your PC may work with a 560 installed with adapters, but it is extremely likely to fry components, motherboard CPU or GPU (have seen this happen often) you dont need to spend alot for a replacement PSU though, what websites do you shop from (assuming you are located in Ireland)
I have gone down the route myself years ago of using a inadequate power supply, and it fried my motherboard when it went after having it a year, I try and prevent others from going down that same route. If i had spend a little more on the power supply I wouldn't have ended up spending $200 on a new motherboard.
