Ok i want to know if my power supply is enough good to RUN this configuration ,i am afraid is maybe some holds up ,or maybe can't delver enough power or something ok this are the things:
The power supply is the following exsact brand and numbers:
CoolerMaster 600W B-Series RS-600-ACABD3-E1
Here is the link with all voltages ,ampers on all rails 3 5 and 12 v:
http://www.coolermaster.com/powersupply/b-series/b600/
Here in this link hase everything about the PSU lotages,watts,ampers etc.
so now i will add my specs here bellow and i want you guys please to give me a straight answer is this goin to be problem this psu for this PC ok ther eis the specs:
{PSU} - Cooler Master - B-Series - RS-600 Watts
{MOBO} - AsRock - H77M
{CPU} - Intel Core i5 - 2320 @ 3.00 - 3.30 Ghz
{COOLING} - Cooler Master - HYPER T4
{RAM} - 8 GB - Dual Channel - DDR3 @ 1333 Mhz
{GFX} - Sapphire Vipor-X - R9 - 280X - OC - 3 GB
{SSD} - Kingston - V300 - Series @ 120 GB
{HDD] - Western Digital-Blue @ 500 GB
{OS} - Windows 8.1 Pro - x64
{CASE} - SAMA - i03 - Gaming Black Edition
I am runing it on ressolution on 1366x768 ,and i play Battlefield 4 on High Settings and Battlefield 3 On Ultra settings,so far i have no problems of any kind ,nut i want to know is the PSU hase enough power = watts on specialy 12v rail with the 47 ampers that it hase and etc..see the link of the psu there is the all amps and watts on every rail,so i don t OC my GPU,or CPU ,although i have 5-6 fans 120mm in my case to exsost air and eneter air ,i ll give you couple pictures of my case, here links bellow:
http://i.imgur.com/NfQ9kHx.jpg
http://i.imgur.com/A0PFwKx.jpg
http://i.imgur.com/R1K9umA.jpg?1
http://i.imgur.com/g4EevBR.jpg
http://i.imgur.com/jDZN9fN.jpg?1
So i am waithing on you guys the experts and anyone who knows if this power supply is good and enough efficient for this RIG ,ok guys i am waithing answers from you immidiatly when you see this and can wrote to me...i really want to know..allthough with that GPU is reccomended 700 watts psu and 750 if you add 2 of those in SLI...
Thanks a lot
Thanks a lot
