is this power supply enough to power this rig ?
Fraxure13
258
my specs I am now gonna buy this on march 24
SPECS :
CPU : FX-8320
MOBO : Gigabyte 990FX-UD3H
RAM : Gskill 8GB
GPU : Sapphire R9-280x Vapor-X
HDD : 500GB WD Blue
FANS : DUAL CORSAIR SP120 and ONE FAN COMING FROM THE CASE,
OPTICAL : Asus branded 😀
I already bought the casing. and I am gonna use my current HDD and Optical.
now for the PSU I am gonna have a Aerocool Strike-X 600w, will this be enough ? and is Aerocool a good brand
Antec HCG-620
http://www.techpowerup.com/reviews/Antec/HCG-620/
Antec HCG-620M not as bad as the non-modular version
http://www.techpowerup.com/reviews/Antec/HCG-620M/
ok ONE LAST question :)
how about this : Antec HCG-620 620W High Current Gaming 80+ Bronze Power Supply ?
Poor voltage regulation on the minor rails (i.e. +3.3V and +5V rails). At 50% PSU load both minor rails will drop below the minimum voltage allowed by ATX12V Power Supply Design Guide Specifications during PSU load changes.
+5V rail drops below spec during crossload testing.
Which review Ko? I haven't seen a HCG fail before.
Edit: I'm guessing the Techpowerup review? I haven't seen that one before. It's odd then that they say this about it at the end.
"Bottom line, If you are on the search for a reliable budget PSU to power your single VGA system and you don't have a problem with non-modular ones, then you should put HCG-620 into serious consideration. It has a good price/performance ratio, is made by one of the best OEMs, Seasonic, and it's accompanied by 3-years of Antec's warranty."
ok REALLY ONE LAST, how about if I compare the HCG to Cooler Master Thunder M 620W 620watts Modular ?
what PSU will have the best quality
