Noah M Honorable Jun 10, 2015 225 1 10,685 Jun 12, 2015 #1 This is the build: http://pcpartpicker.com/p/WZ8MYJ
Solution clarkjd Jun 12, 2015 Looks good to me. The GTX980 only recommends a 500W PSU, so 650 should be good to go.
clarkjd Splendid Dec 7, 2005 6,486 34 28,490 Jun 12, 2015 Solution #2 Looks good to me. The GTX980 only recommends a 500W PSU, so 650 should be good to go. Upvote 0 Downvote Solution
bdiddytampa Honorable Dec 2, 2012 1,012 0 11,660 Jun 12, 2015 #3 That power supply is made by Seasonic I believe, it's a top quality PSU, and good choice for your build for sure. Plenty of amps, good efficiency, and some headroom for overclocking Upvote 0 Downvote
Noah M Honorable Jun 10, 2015 225 1 10,685 Jun 12, 2015 #4 Thx guys! it helps me out a lot 😀 Upvote 0 Downvote
bdiddytampa Honorable Dec 2, 2012 1,012 0 11,660 Jun 12, 2015 #5 Noah M : Thx guys! it helps me out a lot 😀 no problem mate, cheers Upvote 0 Downvote
