Sorry I just missed the other thread about reseating the CPU cooler. I looked through it, and tried the suggestions, but it didn't work.
Right now I am running a 6000+, stock, with a Scythe SCASM-1000- http://www.newegg.com/Product/Product.aspx?Item=N82E16835185042
I have removed the stock fan and replaced it with a Scythe that moves around 88CFM. There are also 2 other fans, 120 mm, and are the same model. The problem is is that the core temps are far different. Right now, idling, with all fans max, Core 0 is reading 37 C, and Core 1 is reading 29 C. When full load is applied, Core 0 reads 47 C, and Core 1 reads 39 C. (Core Temps are from Core Temp 0.99.3.) This is after reapplying the cooling paste twice.
The first time I installed the compound I put the small blob in the middle and squeezed the paste out with the heatsink. I saw the big difference in temps, so i removed the compound thoroughly with isopropyl alcohol, and tried applying the compound in the line fashion. This method resulted in the temps listed above. The question I have is, is it the thermal paste causing this difference? Should I even worry about it? And the last question, how else should I fix it?
