is using a different brand charger with less amps what causing my system to crash when playing games?
Aug 11, 2019
my laptop crashes everytime i play any game plugged in but not when i unplug the charger ..on battery i can play any game..also it charges so slow and it runs out very fast
laptop charger 19v 9.5a
currently using 19v 6.3a
my laptop is MSI gs63vr 6rf stealth pro
13thmonkey
well a 6.3 amp charging is only providing about 60% of the power of a 9.5amp charger, so yes it'll be slower, and could well cause your problems if it runs from the power brick and not the battery.
Aug 11, 2019
I see ..is there a way i can let the laptop run from the battery while charging?? until i replace it
britechguy
801
104
640
20
What the machine chooses to run from is built-in to the hardware (at least on any machine I've ever dealt with), so no.
Third party power supplies in virtually any output configuration you can think of are available on Amazon, eBay, newegg, etc., at very low cost. You should match your OEM unit as closely as possible, and that would be your best bet whether you're replacing the battery or not.
