whiteknights Distinguished Sep 28, 2013 777 1 19,015 Nov 6, 2013 #1 i want to know, when my PSU have only one PCIE connector and my graphic card uses 6pin connectors x2, i heard from some people that its not recommended to use a molex..is that true? and why?
Solution Blaise170 Nov 6, 2013 You shouldn't use molex because it's less stable than a direct connection, but using a molex connection is better than no connection.
Blaise170 Honorable Sep 12, 2013 1,830 1 12,465 Nov 6, 2013 Solution #2 You shouldn't use molex because it's less stable than a direct connection, but using a molex connection is better than no connection. Upvote 0 Downvote Solution
whiteknights Distinguished Sep 28, 2013 777 1 19,015 Nov 7, 2013 #3 Blaise170 : You shouldn't use molex because it's less stable than a direct connection, but using a molex connection is better than no connection. thank you ..you mean that if i used just one 6pin connector to a graphic card uses two, it will work? but using a molex is better? Upvote 0 Downvote
Blaise170 Honorable Sep 12, 2013 1,830 1 12,465 Nov 7, 2013 #4 It shouldn't work to not use it. Upvote 0 Downvote
