I've been searching through the internet for ever trying to answer this question. It doesn't seem like there is a clear cut answer to it. It seems that water cooling used to be a better solution than air, but with the advent of better fan/hs products, this advantage isn't so much. The more I think about it, the more the two solutions seem similar. Water cooling ends up using the same technology, it just does it farther away from the CPU. Instead of the radiator being right on top the CPU as in air, it is located some distance away. The only advantage of water seems to being able to have a limitless ability to increase the size of the radiator.
Some talk about water's higher specific heat. But doesn't that mean that it takes water longer to cool down also. So any advantage in its capacity to withdraw heat is negated by the fact that it's harder for it to lose the heat. I'm out of school here, this is just my rational thinking. Please correct me if I'm wrong.
I might set up a water cooled system anyway because it sounds like fun, but I'd like to see some hard data that indicates watercooling as the superior technology especially with consideration to overclocking.
Right now I have a lapped Opteron 170 at 2.95Ghz that stays at about 57C @ 1.5v on A8N SLi premium. I will have to do the voltage modification to push it any farther, but I would only do that if I had better cooling. My Zalman is smaller 92mm so I could upgrade that, but if water is better . . . . ?
