ISBoxer Suite and Inner Space questions
Wile E Coyote
248
I need help with a setup to use multiboxing in some games.
I have a lot of friends that stopped playing for a while but i need to multibox for some missions.
Now i have every thing setup for SWTOR and this is the hardest to setup for be cause the game does not like multi instances.
But it is manageable.
The one problem i am seeing is that my chars do not follow each-other when i turn the Broadcasting on it will not hit the targets properly and will not follow the main char that i have setup.SWTOR is a little different from wow and other mmos.
Any one have any experience with this.No matter what videos i watch and try it still seems to do the same thing but not for others.
Seeing as you're on the Windows 10 section posting your issue, how have you migrated to Windows 10, via the free upgrade path or a licence key? Have you tried running your games and apps in an elevated command:
Right click installer>Run as Administrator
Further reading.
