Isnt my Xeon E3 1231v3 a bit too hot?
Tempe9
6
Hello guys!
I got a question, I'm using this CPU for heavy duty rendering and some gaming from time to time. I'm wondering isnt it a bit too hot 'cause temperatures under 100% load are reaching 80C. Other example; I'm playing Mass Effect right now and OCCT as well as core temp shows 65 degrees under 75% cpu usage.
Whats your opinion on that? Is it safe? I have stock cooler.
It is safe!
While your rendering your CPU is used almost 100%. 80ºC is good for that numbers and you have stock cooler.
My I7 4790K also goes to 78-82ºC while rendering with an EVO 212.
So your tems are fine for your cooler.
Update:
If you do a lot of rendering I recomend you to buy another cooler for your cpu... I can sugest the Cooler Master EVO 212 for 30€.
It is safe!
Update:
