Hi, I just upgraded my hp pro 3500 MT. I recently installed a seasonic sl2 ll 620 watt power supply and everything was running fine. I attempted to install an hp s700 500gb ssd, I got a usb to Sata cable to migrate my OS to the SSD, however, when I plugged in the USB to sata cable to the computer and SSD, I did not get a device recognization from Windows. I tried unplugging and retrying , nothing. So I thought maybe it was the USB to Sata cable and tried plugging the SSD in an extra sata data and power cable inside the computer. What happened was that the computer started for a second then died like if it were turned off. I tried the power button, the switch on the back of the psu, the switch on my surge protector, unplugging the cable. The power suplly now makes this long beep and a few afterwards continuously. No boot up screen or signal on screen, no source of power, just a strange sound from PSU. I tried another psu I have on the side and the other psu makes the same noise. I don't think the psu is the problem, but I am thinking maybe the mobo? I am hoping the capacitators on the mobo are not shot. Any thoughts?
Specs.
HP Pro 3500 MT
Cpu i3-3220
Asus Phoenix Gtx 1050ti 4gb
tp link wifi pci card
8gb ram
Seasonic S12 ll 620 watt
Seagate 320 Gb 7200 RPM HDD
trying to transfer to HP s700 500GB SSD
Any advice/ help would be deeply appreciated.
Thanks.
Specs.
HP Pro 3500 MT
Cpu i3-3220
8gb ram
Thanks.
