Not so long ago I purchased a Gainward Phantom Geforce GTX 770 in the 4gb model which was working perfectly until recently. Upon playing most games, the frames will drop to around 5fps and then oscillate between 0 and 20.
Games tested:
Archeage Beta
Smite
Company of Heroes 2
All with similar results. Non-graphics intensive games such as Wolf Among Us have no issue.
This is a custom built PC which I put together myself (first build ever!). After the initial construction I have not opened the case. Using the Gainward utility I've ascertained that the GPU temperature does not rise above 40-50 degrees Celsius when playing each of those games on high settings, but the temperature does rise from its base 22 (average) therefore I am lead to conclude the graphics card is functioning.
As my computer still detects my graphics card is there, I am confused as to whether I should open the box, take out the graphics card and plug it back in initially or whether there's a software issue which is the case. This is my first PC so I am kinda afraid that if I do take it out I might make the situation worse... or break it. Live you learn I suppose, but it was rather expensive so I am apprehensive as to whether I should touch it or just bring it back to where I purchased it from (MSY in Australia).
Dx Diag detects my system settings as follows (Information I thought useless omitted, though if I'm missing something important please do tell me):
System Information
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_gdr.140330-1035)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: H97M-HD3
BIOS: BIOS Date: 04/24/14 16:23:39 Ver: 04.06.05
Processor: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz (8 CPUs), ~3.6GHz
Memory: 8192MB RAM
Available OS Memory: 8080MB RAM
Page File: 2325MB used, 7033MB available
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
Display Devices
Card name: NVIDIA GeForce GTX 770
Manufacturer: NVIDIA
Chip type: GeForce GTX 770
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_1184&SUBSYS_118410B0&REV_A1
Display Memory: 8051 MB
Dedicated Memory: 4011 MB
Shared Memory: 4039 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: BenQ RL2450H
Monitor Model: BenQ RL2450H
Monitor Id: BNQ7F0E
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.4052 (English)
Driver Version: 9.18.13.4052
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 7/3/2014 06:48:32, 17555104 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71E3E-52C4-11CF-D47C-89311CC2C435}
Vendor ID: 0x10DE
Device ID: 0x1184
SubSys ID: 0x118410B0
Revision ID: 0x00A1
Driver Strong Name: oem2.inf:0f066de34a958ed1:Section095:9.18.13.4052😛ci\ven_10de&dev_1184
Rank Of Driver: 00DA2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
DXVA2 Modes: DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_VLD DXVA2_ModeVC1_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeH264_VLD_NoFGT
I do apologise for the wall of text! I tried to be as descriptive as possible!
Games tested:
Archeage Beta
Smite
Company of Heroes 2
■ The PC hasn't been moved, but perhaps somehow when I wasn't looking the graphics card could have been bumped?
■ Or perhaps the couple of screws holding the card into place were not enough and it is not connected properly?
■ If it wasn't 100% connected, is it possible for it to still function as it does?
System Information
Memory: 8192MB RAM
DxDiag Notes
Display Devices
Monitor Id: BNQ7F0E
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: n/a
Vendor ID: 0x10DE
Device ID: 0x1184
Revision ID: 0x00A1
