Hey guys, long time lurker, new poster here. I read the rules, I'm no English major, but I will do my best to present this issue as clearly and easy to understand as I can.
To start off, I would like to first state that I have read through the forum over and over, but can't really find others reporting this problem. This leads me to believe that my issue is either operator error, or faulty hardware. I am in hopes that you guys can help me determine which.
My system specs:
MSI Z170A M7 Motherboard
Intel 6700k Skylake 1151 processor
16 gigs (2x 8 GB sticks) EVGA 3200 MHZ RAM
Rosewill 850 Watt PSU, I have used in 2 builds
Corsair H100I GTX CPU cooler
Samsung 850 PRO 256 gig SSD
WD Black 2 TB 7200 RPM storage HDD
NZXT Full tower Phantom
EVGA 980 TI non reference model cards (Currently running 1, attempting to run 2)
Please correct me if any of my specs are a little off, as I'm writing this all from memory.
Alright so here we go. I would like to start off by saying my system runs flawlessly. I have been running the setup for 2 months now, minus the second 980 ti.
Today I received my second card from EVGA, popped my side panel off and installed it. Everything went well on the install. Hit the power button, everything posted.
Loaded to the desktop, and here's the issue. Device manager only reading one card. No sli option in the Nvidia menu, no trace anywhere of a second card being installed.
Rebooted the machine into the BIOS. Clicked the button to explore the motherboard, everything is showing other than the second card. The PCIE slot it's in is reading empty.
Weird, maybe the card is faulty. Pulled my verified working card out, and moved the new card into the first slot. Posted, boots perfectly, reads correctly in the BIOS.
Shut it down, installed the verified working 980 TI into the second slot. Hooked up the connectors, sli bridge, booted the bios. Still reading that the slot is empty.
I am installing the cards in the 2 metal plated x16 slots, everything is seating perfectly, both cards light up and fans work, it just doesn't recognize that there is a card in the second slot.
Due to orientation of the motherboard inside of the case, I cannot check the very bottom x4 lane. Power supply is too close, and there are no cut outs on the case for the stuff on the back of the card to poke through.
Is it safe to assume here that my second PCI lane is faulty, or should I do some more testing before I rip the system apart and return the motherboard?
Hopefully this wasn't too long, thank you for anybody who takes the time to read this and assist me.
My system specs:
