Hi,
I have been having an issue with my computer. I want to upgrade it to a 64-bit system, but when I install a 64-bit processor (they are the right slots; a T5450 and a T6400) the power light turns orange instead of its normal green, the fans and hard drives spin up, but no display or POST beeps are present.
I was worried, so I reinstalled the original Pentium 4 processor, and luckily it still works as slowly as it did before swapping out the processor a few times.
I assume I am missing something basic, like not having enough RAM or the motherboard has no support for the processors I tried to install, bu I would like to have a solid answer and or a fix if you guys have one.
Thanks,
Vaughn B.
Original PC: Gateway MFATXSTL EL2 500L
Motherboard: Gateway El Paso 2 Motherboard 4000777 (original)
CPU: Intel Pentium 4 processor, PGA478 (original)
Video card: NV875.0 Rev B (may be original, unsure)
Ethernet adapter: TP-Link TG-3269 (installed by me)
RAM: 2x PC3200U 1GB DDR 400MHz (may be original, unsure)
Thanks,
Vaughn B.
