Question Issue with a Asus Rampage 3 Extreme
Sep 5, 2020
7
Hey i have some problems with my Motherboard when i turn on the Power Switch this what you see in the Video happens..
The LEDs what are blinking is GoLED and DramLED
CPU is a x5650
PSU is Brand new 550watts
Lutfij
Why on earth do you have no cooler on the board? You should also consult the manual for the motherboard to populate the right ram slot on the board when working with a single stick of ram. Another thing, you need 3 sticks of ram populating slots A1, B1 and C1.
Please include/list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
OS:
Sep 5, 2020
7
CPU: x5650
Motherboard: Rampage 3 Extreme
Ram: 16GB Kingston
SSD/HDD: 2 SSD 1 HDD
GPU: GTX 1060
PSU: Corsair 550Watts
OS: Windows 10
No Cooler because i build it out of the Case
It wont work with CPU on no CPU, With 6Ram of None Ram, and with 3 Ram i have the Same problem. But ist does not Matter if i connect everything or nothing.. Still same issue
Sep 5, 2020
7
If i turn on the Power only this what you can see in the Video happens, Nothing More :( tried different PSU and Ram only when i Press CLR_CMOS it stops blinking, But when i release the button it blinks..
Sep 5, 2020
7
did u try put ram in different slot...i never see someone try run motherboard without cooler and gpu?remove battery for few minute and back in place, disconnected everything and try again
Yeah i tried every slot, it was build in the case everything was connected and i had this issue.. i dont come to boot anyway..
dimtodim
Respectable
Sep 4, 2018
680
64
1,990
14
That board is very old can u check all capators maybe someone oxidate and need replace... Try look if some one bubble or broken visualy.. Sory for my english
