[SOLVED] Issue with either CPU or liquid cooling
Aug 28, 2019
I have a ryzen 7 2700x, liquid cooled with a corsair hydro series H100i v2. Whenever I boot up the pc, ryzen master will show 80 degrees celsius (176 fahrenheit), after just 2 minutes. It will then steadily climb to 101 degrees celsius (214 fahrenheit), cooler fans will go haywire, and the pc promptly shut itself off. If I touch the cooler, its not hot at all, so my take from this is that the cpu readings are wildly off, but im not sure. Any thoughts?
PC Tailor
Herald
Welcome to the forums my friend!
If the PC shuts itself off - it's not wild at all - it's protecting itself.
This sounds to me like the cooler isn't adequately seated.
I would remove, reapply thermal paste and rescure as per the installation guide first.
PC Tailor
Herald
Aug 28, 2019
Is there any way the CPU's thermostat is faulty? The readings have always been a little off... And it has worked fine these past couple of months. Only this past week it has acted up like this.
PC Tailor
Herald
If the PC is shutting down - probably not.
What temperatures do you receive when in the BIOS?
Have you checked that the fan and pump are still running?
PC Tailor
Herald
There should be an RPM in your fans in the BIOS.
That and sometimes just touching the tubing and feeling water movement is a good sign.
You can also use something like HWInfo in Windows for almost everything.
