Hello everyone, this is my fist post.
So before I get into the issue at hand, here is my build specs:
Ryzen 9 5900x
Corsair ICUE H110i Cappelix aio
Asus Rog Strix X570-E Gaming mobo
32gb Corsair Vengeance rgb pro @3600mhz
Evga RTX 3080ti ftw3
9 ql120 fans (bottom 3 intake, side 3 intake, top 3 w/radiator as exhaust)
Lian Li 011 dynamic xl case
Now the issue I am having, is with ICUE software. My cpu temps and my gpu temps are in the normal range. However in ICUE, it makes the led on my aio block turn red because the "Thermal Temps" go up to around 50c after around an hour in gaming.
Any ideas or tips on this?
I contacted Corsair, and they told me that my fan configuration is a great one and I should not change it. My buddy, who builds PC's as a living, told me the same. Is there is a way to get rid of the red led aio block warning or should I be concerned.
I also added a 10th ql120 fan at the back as an extra exhaust, but my temps are not much different at all.
(Edit: My room temp is 69-70f always)
Ryzen 9 5900x
