Issue with monitor wont turn on
Lukas Zickus
hello i have monitor iiyama pl 2200 and it stoped workng, i pluged other monitor and it works fine... iiyama pl 2200 green light is on but it display nothing
Edit:
i read a lot and i found that it might be backlight or inverter but i can't find what specific model i need for my minitpr
Thanks for your report to the Mod team but there is no flaming or spamming going in this thread. I get the impression there may be a terminology problem here.
Lukas - when we RMA a part, we send it back to the supplier/manufacturer for our money back and alexiou thinks you have a strong case to do that. You've proved your system work so it has to be that monitor which is causing the problem. In other words, monitorius yra klaidingas. Siųsti jį atgal į grąžinamąją išmoką.
I had the same issue with my old Monitor which was out of warranty and found it's way to the garbage. Have you tried shining a flashlight at it while its on to see if you can see anything? This would confirm that the backlighting is the issue, which I suspect is the problem. Most likely the backlight power inverter.
