My case is a Lian Li O11D Mini. It only takes SFX power supplies.
The motherboard in this is a MSI Z590 Unify (full ATX)
Power supply is a Corsair SF750 Platinum.
Graphics card is the Sapphire RX7800XT (2x8 pin power)
The issue:
The motherboard in this build has a 6 pin connector for PCI supplemental power at the bottom. Connecting this cable to the motherboard eliminates the proper length of the other connector (there are 2 6x2 connectors on each of the PCI cables) to reach the end of the graphics card to plug in. Even with the other cable I had to do a bit of rearrangement to get even one of the cables there. I am currently using the one cable plus daisy chained plug to power the graphics card, which is not ideal.
I cannot find anything in the manual or online to tell me if this supplemental cable has to be hooked up on the motherboard, and I have not tried without it out of concern. It is my understanding that the PCI slot can provide 75W. I don't know if the other power cable to the motherboard is increasing that or not.
I am hoping not to have to purchase an entire cable extension kit just to deal with this issue if I even need to. When I search for 8 pin extensions all I am getting are sketchy KnM cables. Is it possible to purchase just a 2x8 pin PCI power extension cable for less than the whole kit?
Reference- Antec has a whole kit for $20
The issue:
