issue with pc not booting but has display.
Sattious
hello, so i have a mind boggling issue with my pc.
When i turn it on i get the logos for the graphics card then it gets to the initial black screan with writing on it then nothing.
there is no beep from the motherboard. it sits on the display of the sata drive then it has the flashing cursor. (i have an image for it on where it stops) http://imgur.com/a/3d561
when i take the ram out it gets a ram error code. i dont think its the motherboard but im at a complete loss on what to do.
this is the specs for my pc.
-ASRock 980DE3/U3S3 Motherboard
-AMD FX-4300 4 Core Black Edition Processor
-G.Skill F3-14900CL9D-8GBXL 8GB (2x4GB) DDR3
-EVGA GeForce GTX 750 Superclocked 1GB
-Corsair VS650 ATX Power Supply
-Seagate Barracuda 500GB ST500DM002
-Samsung SH-224DB 24x DVDRW OEM
it has windows 10 installed on the hard drive connected, and i cant get into the bios. i pressed esc and f2 on multiple reboots and nothing. and im unsure what a case speaker is? if its the thing that you can hear go beep when it furst turns on normally yea it has one, it makes a sound when it has no ram in it. but not when everything is in it.
i took the hard drive out to try and get to the bios but i get to the same point in the picture just without the sata device found
