Question Issue with TDP i5-12400f
Oct 8, 2022
5
Hey.
I've recently bought a new i5-12400f. In heavy games in 2K with 120Hz it won't exceed 44 watts or in stress test it mostly shows 36-42 watts of consumption even when stress level is on 100%> temperature is ideal, max 45-50. I've owned other CPUs and never have I seen that it couldn't reach Max tpd. I've looked it up on Intel websites and it showed 65 tpd and 117 turbo max tpd. Otherwise I see no problem and I assume that's better cuz I'll keep a good CPU condition due to low temperature, but I'm afraid to lose my CPU's potential, cuz with current conditions it can't get all the power it needs, it probably exceeded i7-9700 by 15-20% performance wise, been tested on only one game so far.
my pc specs:
Motherboard: Gigabyte UD z690 DDR4 (When I bought it, I set it to the default settings and changed XMP for Ram
Cpu: 12400F
CPU FAN: Fractal Design S24 240mm
Chasis Fan: 3X DARCKFLASH CS 140 ON FRONT, Rear: 1×120mm
Ram: 1x16 GB Kingston Fury Beast
SSD 2XSAMSUNG 980 EVO 1TB
GPU: GIGABYTE Aorus 2080TI Xtreme
PSU: Evga G5 SUPERNOVA 1000W
Case: I modified DEEPCOOL D-SHIELD for good cooling
Yes, but for now you do have lower performance, so assuming your previous 9700 was using dual channel RAM then comparing their performance will not be apples to apples.
And I hope you are aware mixing sticks not from one kit is hit and miss game - it will work or not.
As I know, if timing and frequency are matching then there's no problem, but I'm not going to risk it. Thanks for the warning.
