Hey folks,
I have the following issues with my self-built PC:
Apart from the above the PC runs well with no stuttering, no frame drops and while running fairly intensive games. I initially thought that the PSU was faulty (it was from my old PC) so bought a new one to no avail. I updated my BIOS to the latest version and disabled Fast Start or whatever with no joy.
Specs:
Any help would be appreciated! The issues have persisted for some time and I'm stuck with what to look at/change/replace next.
Thanks!
■ The PC doesn't reliably boot up when I press the power button. If it doesn't boot up and I leave it it will boot up x hours later.
■ When I turn off the PC, the CPU fan will continue spinning.
■ If the CPU fans are spinning, the power button does nothing. I have to press restart.
■ When I boot up the PC it displays the time incorrectly. I have to turn toggle 'Set time automatically' off and then on again to correct it. The time will then gradually alter the longer the PC is on.
Specs:
Mobo: ASRock AB350M PRO4
CPU: AMD Ryzen 2600 3.4 GHz
GPU: Gigabyte GTX 1060 WindForce OC 3GB
RAM: Corsair CMK16GX4M2B3000C15 Vengeance LPX 16 GB (2 x 8 GB) DDR4 3000 MHz
SSD: SanDisk 120gb, Crucial 240gb (reused, from old rig)
Cooler: Cryorig C7
Case: NZXT 210 (reused, from old rig)
Windows 10 Pro v1803 (bought cheap from a semi-legitimate website but activated fine).
Thanks!
