Question Issues connecting monitor to PC (no DP or HDMI connection picked up)
Dec 5, 2022
4
Hi thanks for any help in advance.
So I've had my desktop pc (pre built) for just under a year now and the issue I have had has come up in the past however I cannot fix it now.
The issue is that when I try and use my PC, the monitor will not display anything; the message that is show says there is no DP signal connection found (or HDMI when I try that). This has happened in the past, however I usually just restart my pc, unplug and plug back in the cords and it starts working again. However, this time it is stuck. The issue arose after I shut down my pc and started it up the next morning. Whenever I put it to sleep, the monitor/pc works fine.
I have been able to conclude the issue involves the pc, as I have tried the monitor on a different pc and it works plus I have tried a different monitor on my pc and it doesn't work. I have tried reseating my gpu but nothing changed, and I have also tried changing my RAM slots but that did nothing as well. I have also tried to take my gpu out and run the display off the motherboard but that didn't work either.
I would appreciate any help I can get, thanks!
Specs:
CPU: AMD Ryzen 5 5600G
GPU: AMD Radeon RX 6600
The RAM is DDR4 and I have one stick of 8gb
I have a 500gb SSD
PSU: EVGA 80+ Gold 600W
Monitor: Dell 32 Curved Gaming Monitor – S3222DGM
