I have a 1600x and an Asus b350 Plus Prime motherboard. Trying to OC the processor. Everything seems set correctly. After the OC I boot into Windows 10 and my processor shows running at 3.8 instead of 3.6. However, when I open HWmonitor it shows each core running at 2200 mhz instead of 3800 mhz. I am using high perf power plan. If I restore my bios to default HWmonitor shows 3600. Even if I use the motherboard's built in OC Tweaker that essentially does all the settings for you the same thing happens.
I am on the latest BIOS. Is there some safety setting that is keeping the processor at its lowest clock speed? This seems to be a popular board but have not been able to find a solution. I have the Ryzen Master Application installed but have not messed with it since installing other than opening it.
For reference I followed this guide.
https://www.youtube.com/watch?v=74gO0e-4-A8
I am at a loss at what could be wrong since there are really only 2 settings for the CPU to OC. Also if it makes a difference I can overclock my RAM just fine. Thanks for any help!
