Question Issues reading from/writing to network drive
koberulz
126
Not sure if this is the right section; there are a lot of them.
I have an external USB plugged into a Win10 laptop, networked to a Win7 desktop. It's also part of my Emby media server.
On it are a bunch of ISO files. I'm ripping them to MKV files with MakeMKV (on the Win7 desktop), in order to have video file versions with my Emby server.
However, MakeMKV keeps failing. I've also had instances when trying to play the MKV files via Emby where they've simply stopped, and given an error message saying no compatible stream could be found (which in essence means Emby can no longer find the file, one presumes), only for it to immediately kick me to the next episode. So it's clearly not dropping out for long.
I tried ripping the network-drive ISO files to a local drive on the Win7 machine, and then copying the result to the network drive, but the copy kept failing.
It was working fine for a week or two when I first set it up, but this is happening more often than not now.
Here's a MakeMKV log file from one of the problem rips:
Code:
Debug log started at Mon Aug 19 09:01:12 2019 , written by MakeMKV v1.14.4 win(x64-release)
Using 262272KB for read cache.
001005:0000 MakeMKV v1.14.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\myname/MakeMKV_log.txt
WinCdArb=v1.0.0_tiny win(x64-release)
SDF  v05e: HL-DT-ST_BD-RE__BH16NS55_1.02_211512111440_SIK94G9OE255
No  SDF v05e: ASUS_DRW-20B1LT_1.00
SDF id v05e: ASUS_DRW-20B1LT_1.00
No  SDF v05e: ELBY_CLONEDRIVE_1.4
SDF id v05e: ELBY_CLONEDRIVE_1.4
003007:0000 Using direct disc access mode
003335:0508 It appears that you have AnyDVD enabled. MakeMKV should process discs with most sophisticated protections without help of any 3rd party decryption software. In addition MakeMKV works faster and more reliably when it decrypts data by itself. It is highly recommended to disable AnyDVD and restart the application.
Do you want to continue anyway (errors may follow) ?
003305:0000 AACS directory not present, assuming unencrypted disc
001003:0020 DEBUG: Code 0 at LBL-rg|qsS#(h>P0:121262325
003025:0000 Title #01000.mpls has length of 49 seconds which is less than minimum title length of 55 seconds and was therefore skipped
003307:0000 File 01001.mpls was added as title #0
003025:0000 Title #00000.m2ts has length of 49 seconds which is less than minimum title length of 55 seconds and was therefore skipped
003309:0000 Title 00001.m2ts is equal to title 01001.mpls and was skipped
005011:0000 Operation successfully completed
005014:0000 Saving 1 titles into directory //caplaptop/DVD Backups/Backups/Temp
001003:0020 DEBUG: Code 3221225628 at 2)Me.@84\|r*6W&&&97..1e^:29394091
001003:0020 DEBUG: Code 3221225628 at e7]KVtM7J@G@6#ej:121262417
001003:0020 DEBUG: Code 100859904 at Lt[RKo\%gO`]aK^U:213137574
001003:0020 DEBUG: Code 100859904 at e7]KVtM7J@G@6#ej:121262417
002003:0000 Error 'Scsi error - MEDIUM ERROR:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '15162347520'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '15162347520'
DEBUG: Code 3221225628 at ueX$([U\RyQWMQ{AgE:121262693
001003:0020 DEBUG: Code 3221225628 at ueX$([U\RyQWMQ{AgE:29394758
DEBUG: Code 100859904 at ueX$([U\RyQWMQ{AgE:121262693
001003:0020 DEBUG: Code 100859904 at ueX$([U\RyQWMQ{AgE:29394758
001003:0020 DEBUG: Code 0 at kstXQhz>sC3xud$ta/Bp:29395011
001003:0020 DEBUG: Code 0 at G>ll~IKX!cjdupY+4zj-:29394068
001003:0020 DEBUG: Code 0 at kstXQhz>sC3xud$ta/Bp:29394459
001003:0020 DEBUG: Code 7403490 at kstXQhz>sC3xud$ta/Bp:29393286
001003:0020 DEBUG: Code 0 at D8L"~H<8yPg*12}M1MpW{:213136608
001003:0020 DEBUG: Code 0 at f8>|gG{X=7WBEs]q\xP1:29394022
001003:0020 DEBUG: Code 0 at f8>|gG{X=7WBEs]q\xP1:213140840
001003:0020 DEBUG: Code 0 at f8>|gG{X=7WBEs]q\xP1:29404556
001003:0020 DEBUG: Code 0 at f8>|gG{X=7WBEs]q\xP1:213139506
001003:0020 DEBUG: Code 0 at tz\K>AUip3!R=Ie&:29395908
001003:0020 DEBUG: Code 0 at ^tC$czn8B:EzJrThG:213132698
001003:0020 DEBUG: Code 0 at ^tC$czn8B:EzJrThG:213132146
001003:0020 DEBUG: Code 0 at ^tC$czn8B:EzJrThG:29393769
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
005003:0000 Failed to save title 0 to file //caplaptop/DVD Backups/Backups/Temp/Townsville vs Sydney_t00.mkv
Encountered 28 unclassified errors
error=0x06030000 count=17 name=Scsi error - MEDIUM ERROR:NO ADDITIONAL SENSE INFORMATION
error=0xC000009C count=11 name=OS error - STATUS_DEVICE_DATA_ERROR
005004:0080 0 titles saved, 1 failed
005037:0204 Copy complete. 0 titles saved, 1 failed.
Application exited at Mon Aug 19 09:34:30 2019
Yeah, turns out it's not a network issue as it isn't working locally either. Completely dead now. Works fine on my desktop machine though, so it's an issue with the laptop.
