Hi all,
i build a mining rig with ASRock z77 extreme4 , I5 (4 cores) , 8GB RAM 1600Mhz, SSD 60GB
2x Gigabyte R9 280x
at first everything was fine but from time to time the system crashed and the only way i could get it back is remove one of the video card.
when only one video card is connected everything is working fine - driver is working perfectly.
btw - i switched between the cards just to make sure the video cars is not the issue(works).
now when i'm connecting the second video card the windows is starting up(windows 8) and the screen went dark. and that is it.
i removed one card went back to windows completely remove all drivers
and than restart with two of the video cards connected.
this time windows recognized both (in Device manager) - generic video driver....
however - one of the cards is showing exclamation mark saying the driver is not matched the hardware.
the other card is fine (device working properly)
i tried re install the driver and back to square one - black screen after window starts loading.
any suggestions?
Thanks a lot!
Isaac
2x Gigabyte R9 280x
any suggestions?
Thanks a lot!
Isaac
