Im sorry that this post is so big, but i have had sooooo many issues over the last months with these cooling related problems that i just felt the need to put them all in one post..
Hi i have an issue finding a good way to controll my computerfans and/or waterpump, i have been trying multiple solutions without much luck. i have 3x140mm fans (two of those are for my radiator and one is in the back) 2x120mm fans + 1x90mm fan in the front. My watercooler is a cooler master nepton 280L. and my chassis is a haf stacker 935.
Now my issue is that my system is way too noisy now, i can still hear it through my headphones playing music at half volume. I started off using Asus ai suite 2 to controll my fans and for viewing system information.
Now i uninstalled that software because i have had lots of issues with it aswell as most people just doesnt recommend using it(for overclocking at least... 😛) I also tried speedfan, which i have seen most people recommending as far as fan controlling software goes. But fanspeed only seems to let me controll my 1 fan in the back
It allows me to controll 3 fans, but the second one looks like its my pump(which doesnt change speed if i try and do so), and the third one isnt connected or something...
And without any software my fans constantly run at probably 60-70% speed. I have even looked in the bios, but with no luck... its basicly making me crazy as i cant even play games without noticing the humming from the fans...
While this software did indeed lower the rpm of the fans in my case significantly, it still did not cut it. 🙁
Now, when i had ai suite 2 installed i was able to shut down most of my fans by putting the computer in energy saving mode, i still thought it was pretty noisy for when im trying to do homework. I think its the pump thats so noisy, is it possible to lower the rpm of the pump or will such an action damage the pump over time?
I was actually able to controll the pump rpm like the first few months i had my computer but for some reason i just wasnt able anymore after a while...
I asked the cooler master forum if this was an issue, and the response was that it was supposed to be running at max speed. Now when i have got to use my computer for almost a year now im constantly finding it troublesome that the pump is making so much noise. So is there anything i can do?
Now just to sum up, i will calrify that my temps are not an issue(25 degree cpu at stock idle, and gpu at 40-70 degrees overclocked) Its like the speed of the fans aren`t even controllable its just stuck at constant speed fluctuating at random times for a few seconds, it doesnt increase fan speeds or anything when it gets hotter for instance...
