Question Issues with HDMI on Radeon R7 265
DavePenn
7
Hi
I have an interesting issue with the Sapphire R7 265 and 3 displays.
I have 1 monitor connected DVI/DVI, a second connected DVI/HDMI and I want to use my TV as a 3rd display for movies etc. The connection is HDMI>Wall plate>HDMI 10m cable sub-floor>Wall plate>HDMI to the TV.
The issue that I am having is that it is not correctly displaying on the TV, the picture has bands, whites are showing as pink and there are random blue patches. Now, I can use the HDMI output from the onboard card (Intel HD 4600) and my monitors connected to the R7 without any display issues, however whenever I turn the TV on with this configuration the PC will freeze up.
I have the latest drivers and I have checked the card is inserted correctly...
Does anyone have any ideas?
Cheers
Jonathan
Ok, so further update.
The card is an R7, so it can only support 2 monitors via HDMI/DV-I, the rest have to be via display port.
I connected a 3rd monitor in place of the TV and the signal was fine (I had to deactivate a monitor to get it to display) but if I use the TV instead of the monitor, the signal is "fuzzy".
The issue seems to be compatibility with the TV and the card, which I haven't heard of before
