S SabreGames Commendable Jul 3, 2016 2 0 1,510 Jul 3, 2016 #1 I am thinking about installing a new corsair cooler, but 2 standoffs are behind the window cut out, what to do??
Solution Zerk2012 Jul 3, 2016 When you remove your current cooler you might be able to just slide the back plate in place if not then remove the motherboard.
Zerk2012 Titan Ambassador Oct 6, 2014 22,361 2,432 104,240 Jul 3, 2016 #2 What cooler, it looks like your going to have to remove the motherboard. Upvote 0 Downvote
S SabreGames Commendable Jul 3, 2016 2 0 1,510 Jul 3, 2016 #3 https://www.amazon.com/dp/B019EXSSBG/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687562&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0051U7HMS&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=WB4ZSN3M2R5A862JSWQM Upvote 0 Downvote
Zerk2012 Titan Ambassador Oct 6, 2014 22,361 2,432 104,240 Jul 3, 2016 Solution #4 When you remove your current cooler you might be able to just slide the back plate in place if not then remove the motherboard. Upvote 0 Downvote Solution
