Issues with my GTX 1080, please help!
MercinwithaMouth
56
I'm consistently having fps drop spikes every couple of minutes across multiple titles. I recently bought the build from my brother who barely used it.
I updated the GPU drivers before I brought it to my place. I was having fps problems with WoW and Metro: Last Light, but then I remembered to update drivers. I thought it made things better but WoW is still pretty bad about the drops and has stutter. Overwatch also has drops. Paragon didn't have any before I updated the drivers but now they're apparent. These drops are heavy too, getting me down to frame-by-frame kind of gameplay for a few seconds and then it straightens out again.
I7-4790k @ 4.00GHz, Nvidia Geforce GTX 1080, 8 GB RAM, Windows 10, MSI Z97 Gaming 5 MOBO
have you checked the gpu temps while this occurs? Is it a reference model or a 1080 with an aftermarket cooler.. 8 GB of ram is also a bit on the short sight. shouldnt give you any issues. just saying with a pretty decent cpu and gpu, ram should also reflect in your budget.
Yes, the reference I believe. I'm not sure what I can do to help the CPU other than get something better than a stock-fan. I'm not sure how I would know ambient temps, really. Something like 60f I feel.
how many case fans do you have? and what do they do... you could try to increase the fan speed of the gpu by using something like msi afterburner and get a more efficient cooler for the cpu in order to improve the environment inside the case.
2, I believe. One on the top that blows air in and one in the back that blows air out.
Used MSI Afterburner to find that when I was playing WoW, the physical RAM was hitting over 7700. I put in the other 8GB of RAM and the problems seem non-existent so far. Was it possible my games at such high settings were bottlenecking the GPU/CPU due to RAM?
MERGED QUESTION
Question from MercinwithaMouth : "RAM bottlenecking PC?"
You may have been running out of ram thus "paging to disk".
