Issues with outputting 5.1 Surround through HDMI
kittybooze
97
My two options are as follows and they both are possessing big hurdles I can't manage to get through
1. While trying to setup my computer through a passthrough on my Onkyo HT-r557 Receiver, my computer fails to recognize the monitor I'm trying to connect to. It will display the monitor just fine on startup but when windows is loaded, my main monitor just starts blinking off and on and not showing up at all on the monitor I'm trying to use. The receiver has the proper port selected as a DVD on Hdmi port 1. I'm wondering if some sort of limitation on this older receiver may be causing this but I'm unsure.
2. While outputting through hdmi straight to the monitor, and using an optical cable to connect the tv to the receiver, I do not get the option to use anything but stereo. 5.1 is not present. I made sure all of my drivers were up to date and I see no reason I wouldn't be able to. I see that there are options within my sound settings called "Nvidia output". There is two of them, I don't know if those are related but they say "Not plugged in." For your reference, I'm using a Z-170A asus motherboard.
Ultimately I just want the best sound with any added convenience.
optical cable will be forever limited to stereo PCM due to low bandwith....dont understand why are you so hooked on it that much...
so the only option is HDMI, it can send uncompressed 7.1 just fine, but your device has to support it
some of your TV/receiever settings are messed up as gpu doesnt see anything behind your TV, and your tv acts as a 2 channel stereo, so your nvidia wont let u use more channels
so either pc -> receiver with hdmi cable or fix your tv/receiver settings
Sorry about that! To be more clear I was explaining that to just show while attempting a passthrough on the receiver my main monitor was working but blinking throughout.
I have 1 computer monitor and 1 55 inch TV.
So PC -> Monitor
PC -> Receiver -> Tv
But also I'm currently running the
PC -> TV -> Receiver. Using the optical cable as I described to connect the tv to the receiver. This offers decent stereo sound but no 5.1 as far as my computer is telling me.
So you're running dual displays. AVR will be picked up as a 2nd monitor from computer, have you set windows to duplicate display or separate? If Duplicate, check resolution matches to your monitor and AVR. Assume 1080p across everything?
Optical is only 2.1 stereo so thats expected.
What happens if you connect your monitor via hdmi out of the AVR instead of the TV?
Should have asked what connection does your monitor use?
Both screens are 1080p. I have seperate monitor displays. I can try the monitor idea.
I have now also routed the video to my regular computer monitor, the video comes through just fine but the sound is still not cooperating at all. I've tested my ps4 on the passthrough and the sound only comes through with an optical cable connected.
To put it simply, I want my hdmi cable to carry the sound throughout to achieve convenience and quality, but my receiver seems to have no option to do so, so I suppose I'm left with the optical cable option. I don't see why my receiver would have two HDMI ins and one out and not manage to shove sound through it but it just might not have that capability.
Since your receiver is supposed to handle the sound from sources connected to it that audio isn't sent to the TV over the HDMI connection. The optical cable from the TV will send audio only from the TV tuner and apps. Optical will handle 5.1 but not lossless audio like Dolby TrueHD.
The simplest solution is to connect the PC directly to both the TV and monitor. Your other sources connect to the TV. Optical audio will now carry the audio from all you sources to the receiver. Set the TV to output in bitstream and you will get surround sound.
My only issue now is getting windows to output the 5.1 surround through HDMI. I have updated the drivers and everything yet it refuses to send anything but stereo. I know full well my motherboard is capable. I know my receiver and tv is capable of course. So I'm looking for anything perhaps in motherboard settings or any strange glitches caused by problems with windows 10 or nvidia's hd audio driver. I haven't the faintest idea what to do. The only things that appear capable to send 5.1 surround is my analog outputs and the wireless usb headset I have.
DTS Audio, Dolby Digital Plus, Dolby Digital
Are listed, despite not being able to output anything other than stereo.
Max number of channels: 2
oh thats easy, first u need some sort of video like dvd/bd or ac3 audio which has dts/dolby encoded audio
then u need player which can passthrough those codecs (vlc media player can do)
and thats pretty much it
the other option would be to use analog surround (5.1/7.1)
and another option would be to get soundcard which can encode 5.1 pcm to dts/dolby (lets say sound blaster z)
Is the implication that, I don't need to enable 5.1 surround sound in windows. That the individual program is the only thing that matters?
here looks settings for vlc
Thats strange actually.
I've connected a GTX 780 to a Yamaha avr with a hdmi cable before and got the options to set 7.1.
Which Nvidia card do you have and have you installed drivers from GeForce.com? Windows generic drivers doesn't include complete audio package.
I have a GTX 1070. I have downloaded the latest drivers including the HD audio. I have even uninstalled the driver through device manager but that changed nothing. I had the idea to try other drivers but I don't know where to start.
