[SOLVED] Issuing with power suppy
technicaltutorials84
Commendable
Dec 20, 2018
33
Hello friends
I from India and I have Indian local power supply foxin FPS 800.
I have problem with my power suppy. Everytime when I apply some load like blender rendering power supply fails after 15 to 20 minutes. but normal work is ok.
Now I am planing to replace with Vs450 or Vs 550 is it ok?
VS is 2 steps better than Foxin, CX is better than VS. IF the newer versions that are black+silver. Do not buy the older versions that are still available that have colored, blocky lettering. Either 450w or 550w is good, if your video card has pcie power connection the 550w would be better.
thanks for reply
some people are recommend cooler master 500 to 600 watt
corsair cx vs cooler master
