Question It it OK for my CPU fan not to spin?
pepekuci
5
I was stretching around to the back of my case and saw that my CPU fan isn't spinning. I put a mid load on it and the temps on all cores stayed at 40-50C, but the CPU doesnt spin. Anyone know should i be worried?
pepekuci
5
The cpu fan is definitely plugged in? To my knowledge the fan should always spin even if it's at a very low rpm. You may try putting a heavier load on and see if the fan kicks on.
I will, as far as i know if it wasnt plugged in it would show the "CPU fan error"
